- Sun Oct 20, 2019 2:50 pm
#86124
' 86 350. I'm trying to separate the gearbox halves- the gasket is leaking , its a long story. Theyare stubborn. I've done it before years ago. remind me, does the position of the kickstarter shaft make a difference? ie. do I need to make sure the pawl is retracted? I have undone all the bolts and screws including the mainsheet -end left hander. I get some movement pulling them apart but I suspect its the kickstarter/layshaft end that's the problem.
Technical notes are not showing up at present!
