Copied from my answer on your other thread on this subject:
I suggest you take a close look at the fuel tap. I've had a "high speed" weak mixture problem on my low mileage but neglected, 2004 iron barrelled 350 ever since I bought it a year ago. It suffered exhaust valve seat recession and a damaged exhaust valve (tappet was closing up almost every time I rode it), despite having rebuilt the Mikcarb 24 mm carb and ensuring it had the correct jets (it was very clean inside). It would also misfire if held on full throttle for more than a few seconds. I had a new valve seat fitted and put in a new valve. I also fitted a larger main jet and a richer valve slide an attempt to richen it up. All that did was to cause it to misfire sooner on full throttle. Briefly closing the throttle allowed the engine to pick up and run again. On a hunch, I rode the bike till it misfired then immediately switched off the fuel tap. The engine then died completely. The penny dropped - the engine was able to empty the float chamber so there was a fuel flow restriction. I fitted a two foot length of plastic tubing to the tap outlet and watched the tank drain into a can - the flow was slow, but constant over time. I took off the fuel cap but the flow didn't improve (confirming no partial vacuum caused by a blocked vent on the cap). I took out the fuel tap to check it over. Perfectly clean, apart from a few paint flakes on the filter on the standpipe. I then took it apart to check for an internal blockage, there was none. I drilled out all the fuel passages to a slightly larger size - no better. I then realised there was some moulding flash on the second, lower filter inside the little plastic bowl under the tap body. I carefully cut this away with a Stanley knife blade. I also noticed how very fine a mesh this filter had. This didn't seem to make much of an improvement on the road. I was beginning to despair and was about to look for a different type of tap but then in a flash of inspiration questioned the fuel system design, in that were a total of three filters between the tanks contents and the carb because there are the two in the tap and a third, canister type filter in the fuel line itself (which I believe is standard). I took the tap apart again and completely cut out the mesh of the bowl filter (the canister filter will catch anything in the fuel line). Problem solved; the fuel flow improved quite noticeably and if anything the smaller main jet can now be put back in, which will reduce the fuel demand anyway.
By simon
#78939
I had an early 350 Redditch Bullet that did the same thing. I assumed that because it had a white metal big end that it couldn't be oil supply to the bigend as it would have failed before seizing. Finally after replacing pistons and barrel I split the crank to discover that someone had replaced the white metal collar with a roller bearing but hadn't cleaned the white metal from the previous bearing out of the oilway. Problem solved.
