This is what I did. Although the angle-iron looks a bit wonky but is only out by about 2mm against the spirit level, the spirit level is dead straight, both extend past the front wheel, wheels on the deck. The clamp partly seen left of pic was used to hold both against the tyre. The axle stands are on their lowest setting. With the notches 12/12 the front wheel was a long way to the left, with the notches 10/12 it was a long way to the right, with 11/12 it was dead centre. Because we can only adjust by one notch there is no real need for a precision jig.
