- Tue May 01, 2012 9:07 am
#12124
Hi John. That is it...if one uses the word vacuum, then one should qualify (quantify?) the actual amount of relative lower pressure by adding the words "partial" if there is not a complete zero filling of atoms, but in practice this is never possible not even in outer space. As it's therefore impossible to achieve a perfect vacuum we generally describe any strong low pressure in everyday language as a vacuum. The dictionary suggests these meanings: a. Absence of matter....b. A space empty of matter.....c. A space relatively empty of matter....d. A space in which the pressure is significantly lower than atmospheric pressure. So if we use "vacuum" with the meaning as shown in c or d then, as you say, vacuum is correct and acceptable. However, I guess everyone would understand the everyday commonly used word "suction" as the perceived action and effect that a vacuum can provide or create. Everyone is familiar with the effect of sucking (be serious now!) such as drinking from a straw where one moves liquid against gravity by creating a lower pressure in the mouth. We also have the description "vacuum cleaner" and no one questions the term or suggests it should be called a “suction cleanerâ€. I have to agree though with Trevor, that using the word suction would have been the better word as it describes the action I was describing rather than the scientific pressure difference which then also requires a second thought as to mentally picture the process of moving the oil along the oilways to the pump. Many thanks and best regards....Les
PS just noticed your new post Trevor,before posting the above and coincidently you've mirrored some of my same points..never mind ATB...Les
