- Fri Sep 19, 2014 7:43 pm
#39895
Ally just going by that I think you could run either the 2 purples and not use the orange/yellow or you could use mode 1. 30 volts A/C is good I have seen 17 volts A/C and still get 13 volts D/C. With yours I would have liked to see a bit better D/C output but obviously that is what the Power Box is maxing out at. Power Boxes are not perfect either they can give varying outputs as well I have one that sits at 14 volts all the time even just using the 2 purples so it is ridden all the time with the lights on to stop it overcharging the battery and who would have ever thought a Super Meteor would have ever had an overcharging problem
