- Fri Aug 17, 2018 9:31 pm
#78628
Hi, where are you situated? Check if gears are selecting by raising rear wheel off ground, turn wheel by hand and try to engage each gear by moving neutral finder by hand. If gears engage problem maybe in selector mechanism. Questions. Has this been disturbed ? Does the gear lever centralise when moved up and down? If not weak or broken selector spring. There are two. Lastly are you trying to engage gears without rotating gearbox? The dogs need to line up. Try turning engine over on the kickstart as you select gears by hand. Vince
