- Sat Nov 14, 2015 10:01 am
#52403
Rattlebattle & loosening up - I find the engine noise from the C5 UCE is a quiet putter, push rod chatter being normal. The exhaust note through the 50s is another matter. I felt the motor loosening up before 300 miles, it was stiff initially, while by 600 miles it had probably got to 90% run in. I shall probably give it to 1200 miles before giving it a full chat, it's just under 1000 now.
Keep half an eye on the cables, the originals are stretchy, the clutch does a tight turn in the casquette and the throttles do a u-bend under the seat. The throttle do self-adjust annoyingly. The english clutch cannot cable follow the tight path of the thin indian one, it had to pass through the casquette and down the exhaust side. The throttles and 'bistarter' can be eased out with a slight re-route from under the tank; the bistarter routes better if it doesn't go through the casquette at all (no room through the hole for it with the thick english clutch). The english clutch cable has much less give in it, the clutch switch doesn't allow one to start unless it is pulled all the way back to the bar even though the clutch has freed off; I feel a small mod to the switch peg coming on.
