By John M
#51173
After a bit of googling, I have discovered that super-unleaded now has 5 percent ethanol as well, ho-hum..................
By Scalyback
#51174
[center]
I checked a few months ago, Esso and Total did not put it in 97, but things may have changed.
What is the point in hiding it in the UK? In Europe the pumps are labeled 95 or 95-E5 or 95-E10?
this is in Dutchland, NL, but you get the idea, same in France!
By simon
#51175
Dilute ethanol is very nice. Good luck with the knee replacement. My 88 year old Mum has just had one and it was an outstanding success. Brilliant piece of kit!
By Les
#51191
I think you will find methanol which I use in my model engines is the poisonous one very similar but a different chemical make up it still attracts water and is also corrosive epically mixed with nitro and gets in contact with moisture
By Les
#51192
Blimey all those posts in the time it took me to write one line
By Scalyback
#51194
yes and two days before yours!
Les, you didn't spot there was a page two did you :-)
By Beezabryan
#51200
With help from 'Er on t' Pillion I staggered round to the garage - the Bullet is still there, first time I 've seen it since 30th August. Due back in hospital monday so I thought I'de better check :) Flash & a Box is looking OK too and that was last ridden (with difficulty sometime in June, I think.
By Les
#51211
I have been installing Windows 10 on two computers my brain cells need a rest
By apparently lucky eddie
#51219
Windows 10 - almost as bad as the dreaded Vista! Don't forget you only have a couple of weeks to try it out and then revert to the previous system or you're stuck with it :(
By Beezabryan
#51220
Every incarnation of Windows seems to be worse than the one before, I'm quite happy now with Vista!
