- Mon Jul 14, 2014 6:51 pm
#37403
Thanks for your comments, Frank. You wrote: " It can make its way there all the time but I guess it is more likely when the pipe becomes restricted and it cannot expel fast enough, pressure builds up and it is forced through to the can. By the time it is completely blocked, and even then under pressure some might get forced through, the damage is done. Think restriction or severely restricted if you like rather than blocked." The reality is that I just can't visualise the mechanism by which the partially blocked breather forces oil into the separator, probably because I no longer have an Electra X in front of me to examine! Anyway, I'm going to pore over the exploded diagrams on this site and see if I can draw myself a diagram of the entire breather system. Thanks again.
