- Mon Apr 15, 2019 10:37 am
#82486
Eric,
the tappet as you describe is indeed a weak point, the head can snap off the stem, regardless of whether you get the valve lifter to work or not! I never got the valve lifter to work on mine, but the exhaust tappet STILL failed, so it's as Norm mentioned previously, someone took a perfectly sound component of the old Bullet design, and redesigned it into something more fragile.
Also, the lifter spindle boss on the tappet cover cracked on mine when I did try to use it and it caused a quite impressive oil leak.
