- Tue Feb 05, 2019 9:04 am
#81315
Kram, hopefully you can go through some of the basics on this step by step to get up and running, even if its just with limited knowledge.
As Mark says, the Jack Gray article listed in the technical notes section on this website is an excellent information source for the 250 unit engine and is a great way to familiarise yourself with some of the basics.
I would recommend going through the following to try and ensure there is nothing simple missed:
- Make sure you have a good known plug.
- Fresh fuel in the tank.
- A good fully charged battery.
- Double check that you have set the ignition timing on the correct stroke (remove the valve cover and physically check this is opening at the right time).
- Check that the push rods are not over adjusted and holding a valve open, good compression would indicate this is okay, but with the valve cover off its no time to confirm.
- Check the push rods are positioned the correct way around (they can be fitted incorrectly on the 250 Unit so the exhaust is opening on the inlet cam follower and visa versa, the correct way around is for exhaust push rod to come up from the inside of the push rod tunnel, and the inlet push rod to come up from the outside of the push rod tunnel).
- Check the connections on the back of the ammeter that they are secure (I have had a connection work loose here, which was enough to give a intermittent spark).
- You say you have a good spark, is this sparking all the time after each kick and not just a good initial spark with the first revolution of the engine after the ignition has been turned on? (if wired incorrectly you can get a good spark after the ignition has been turned on for the first turn of the engine).
- When you attempt to start the bike, try just turning the fuel on without tickling the carb and with no choke at first.
- I assume you have converted the bike to a 12V system now as you have a Boyer fitted? Have you got the ignition switch positioned to the normal running position and not emergency start (I cannot remember if it will still work on emergency start with this setup)
If you need more clarification on a particular point, post back on here and I am sure someone will help out.
