- Tue Sep 13, 2016 5:36 pm
#62260
Hi again, the side stand is fitted as you said off the footrest bar and rear bolt 145885 which passes through the rear of the lower engine plate. This can be moved over as you require. The centre stand is pivoted on a bar which passes through the engine plate in front of 145885. Vince
