- Wed May 18, 2016 7:44 am
#58223
i think i have sorted the starter issue, i stripped and cleaned the sprag clutchm not alot of dirt and it looked fine, stripped and tested the starter motor again everything looked fine, re-assembled and it is now turning over the engine as it should, not just once and then stopping, so i think that is now fixed. I have not attempted to start it as yet, i am going to strip and clean the carb again but how would i check the ignition timing without the bike running ? How do you do static timing with electronic ignition? I looked at the electronic ignition and it has a mark on it which is still lining up so i dont think anything has moved but as most on here are saying to check it i think it is best i do before attempting to start it.
Thanks for any help.
