- Thu Jan 28, 2016 11:50 pm
#54748
if i am correct eBay item 301846302635 is lucas part 47507 as you can find in this list.
ATD units and application list
this on will need the most work to work correctly.
it has to much advance, so this needs to be adjusted.
then get a idler pinion.
get this reworked to fit on the ATD and aligned with the other idler pinions, rivet it back together, remount end ring.(not forgetting to check al part for wear and correct play)
and bob’s your uncle.
