- Sun Jan 24, 2016 11:36 am
#54473
papasmurf - that's not what Ashbury and Hawkesworth said, the last paragraph is particularly telling, plus there is a considerable difference in consequence between a simple chemical reaction combining H & O and combustion/explosion - "2.3
SUMMARY OF FINDINGS
To summarise the findings from the paper by Astbury and Hawksworth, they concluded:
Hydrogen does not necessarily ignite spontane
ously when released at high pressure.
Compression ignition, Joule-Thomson expa
nsion, diffusion ignition and hot surface
ignition are unlikely ignition mechanisms fo
r most accidental releases of hydrogen at
ambient temperature.
The postulated mechanisms described in the literature and discussed above do not
account for all the reported ignitions a
nd non-ignitions of hydrogen releases.
There is the possibility that when hydrogen
does ignite on release, two or more of the
postulated mechanisms are present together.
It is possible that some form of electrosta
tic charging is a part of the mechanism where
spontaneous ignition of leaks of hydrogen
from high pressure has occurred at ambient
temperature.
Further work is required to establish the
conditions under which hydrogen releases
ignite, particularly with resp
ect to electrostatic phenomena.
