- Mon Mar 02, 2015 7:18 pm
#45024
Yes of course Pete you are correct, but that is not the issue here, my point is that the jet size is unlikely to be the OPs problem. When you choose a carb size a lot of things need to be taken into account, the carb has to be matched to the diameter of the manifold putting a larger carb on just slows the airflow though the actual carb and upsets the low/mid range running and does nothing to improve the top end, a slightly smaller carb will lose a bit off the top end but make the bike far more pleasant to ride on the road. If tuning for speed then you need the best gasflow possible with a bigger carb/inlet tract appropriate to the engine involved, but for most road users this will ruin the pleasure of a good low to mid range, depends what you are using the bike for but honestly I have seen many a good road bike ruined by inappropriate tuning. PS how on earth do you put seperate paragraphs on here?.
