By Lessus
#9637
Bulb arrived this morning.
Well done Hitchcocks!.
And there was light!.
Off for the MoT tomorrow.
By Lessus
#9639
One last thing, does the rear brake only trigger the brake light..not the front one?
By Paul M H
#9640
When the front brake lever is pulled it should operate the Rear brake light if its not check the switch on leaver is working ok sometimes a spray with wd 40 gets it working ok.
By Lessus
#9641
Just had a look at the front brake leaver, there is nothing else attached to it apart from the brake cable going to the front brake. There appears to be an opening where something may go, but that something is not there!.
I pressume thats what you mean, a switch that activates the brake light.
Is this a fail?
By MadMike
#9649
Lessus I am slightly confused here. Your bike is 1997 Bullet and so this would be its 12th MOT. Did it have a stop light switch last year or in any preceding years? How long have you had it?
By Pwayman
#9650
Taken from the MoT testers notes:
Machines first used on or after 1 April 1986 must have a stop lamp that operates from both brake controls.
However, a small number of machines first used from this date were approved with the stop lamp operated by only one control. A machine should only be failed if you are certain that it was originally manufactured to operate from both controls
By Beezabryan
#9651
That opening below the brake cable on the f/brake lever mounting is where the stoplight switch should live.
See on line parts Indian Bullt 500 1996 last page item (24) item
Position 9
SWITCH with cables, MAGURA,
Code: 141892
Price: £7.50
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
No Switch = MOT failure
By Lessus
#9655
Thanks for that!
Part ordered.
The bike came over here in 2002 and as far as I am aware has just sat there, hence milage of 16 km and the flat tyre when I swapped my Vtr for it.
By Midge
#9676
Hello Lessus, I had a look at your Ebay advert 120862031866, it would be a shame to sell it due to minor problems, I'm sure someone local to you would help you with it.
I would help, or maybe even buy it, if I was closer.
By Lessus
#9678
Thats a good idea!.
If anyone lives near Sunny Stockport (Cheshire) and could maybe spare half an hour to give the bike a gander, it would be very much appreciated.
Tea or perhaps something stronger would be provided!!!!
