Beezabryan and Leon, I've learned two lessons from this; lessons which I already knew, which makes it even worse. Firstly, don't make assumptions (like I did about the age of guru's bike). Secondly, don't be so rude, pompous and arrogant, when there is no possible reason to be so. :-/
Oh, I've learned a third thing: that there is a vast difference between the recommended front tyre pressures for old and new Bullets. I think it was Beezabryan who mentioned different tyrewall stiffness in modern tyres. However, I'm not yet convinced that is the full story, because we haven't seen a similar reduction in pressures on other makes (or rather, not on my bikes, which cover about the last 40 years).
My "gut" (which is substantial, thus hard to ignore) tells me that 18psi should be way too low. However, I've had mine set at that pressure from new, and I have to say it feels absolutely fine. I suspect this proves I'm not at all a perceptive rider.
