- Wed Sep 10, 2014 5:57 am
#39658
Hi again fellas. I tracked down my compression issues to my spark plug not fitting right. It has never seated in fully since I got the bike and I guess it's just got worse and I put the miles in. With a listening tube I could hear air escaping from around it when I pushed the kickstart. So, I have the head off, have confirmed the valves are not the issue and have the kit from our hosts (the more expensive one) to put a repair in. I've talked through the procedure with several people and reckon I know what I'm doing. Going to try find a bit of scrap metal to practice on first too! However, a couple of things I just wanted to run past everyone on here: the instructions make no mention of loctite on the insert threads and most advice I've read online says it can make the insert come loose later, correct? The other thing was my engineer neighbour suggested I recut the thread from underneath as it was less damaged there and that would allow the guide to go in accuracy. Would this result in the spark plug screwing in counter clockwise when I finish, would that matter? A little apprehensive about it but it seems like a simple job if I take my time. Thanks guys!
