Catastrophic sequence in the blink of an eye... Piston crown seizes at the start of the downward power stroke, flywheel inertia plus bike momentum/weight rips the piston apart at the weakest point, just under the oil ring land, leaving the flywheels and con rod to continue on there unfettered way.. Around and back up the bore..
Meanwhile the exhaust valve starts to open and maybe hits the piston top still seized in the bore, not long after the sledge hammer of a con rod tries to reconnect the two piston halves, blasting the exhaust valve and push rod, maybe damaging the rocker fixings and cam surface.. Con rod has to go somewhere so goes through the piston twisting as it goes. Tremendous forces at play.. It was at this point that the con rod snapped on my BSA and the next rotation saw the half conrod exit through the crankcase..
Its that deathly silence that gets you as you come to a halt.. Mine was piston too tight in rebore and maybe running weak and hot..
Nothing to do with racing my mates Morris 1000 with the Riley 1.5 twin carbed engine in..
