- Fri Jul 18, 2014 8:24 am
#37726
A very good point (sorry!) about the choke on a Micarb. A few years ago on this forum, when Mr Hitchcock used to join in on postings, I joined a discussion about starting problems in which one or two people were saying that the choke was too weak and causing start problems.
I replied that it was in fact the opposite, and these days, with my 2003 sixty5, I use the technique stated above of one or two turn overs with choke on, ignition off, using decomp, then kick start with ignition on.
If you keep kicking with choke on you WILL flood engine and wet plug.
BTW, if engine does get flooded, to clear it, turn ign off, open throttle wide, and kick through a few times with decomp open. Then try start without choke.
