- Fri Feb 07, 2014 11:11 pm
#32742
1. Indian Bullet, exhaust tappet closed up, lock nut not tight enough, would run but not rev, took a while to work out.
2. Indian Buullet, head gasket, my fault, didn't re-torque the bolts after it had run for a while.
3. English Bullet, centre nut on the clutch unscrewed. Replaced nut and spring washer with an Indian nylock nut.
4. English Bullet, found that Lucas SR1 magnetos don't work under water! The cover has a gasket but the screw holes don't.
