- Tue Oct 15, 2013 8:43 pm
#29501
Hi Roger, I don't know the original reason but there could be a couple that I have thought of. First one is that some countries require the headlight to be on at all times. The factory knew how poor the charging system was, so they decided to fit a 4 wire stator and split the coils up and use half the stator to charge the battery and the other half to run the headlight. This meant you were not drawing any power from the battery to run the headlight so you wouldn't end up without enough power left to run the ignition coil. The second theory I have was with the introduction of the electric start they could run the headlight as A/C and not draw too much power from the battery so you could still be able to start the thing. What I haven't been able to establish is when they first started fitting the 4 wire stator. I am working on 3 late sixties 350 Bullets at the moment and they all have 4 wire stators and the A/C D/C setup. Obviously this was not factory but it helps blur the info I have tried to gather
