By Boxerman
#89081
PeteF wrote:
Wed Apr 08, 2020 1:40 pm
It's GT 535, wet sump.
Yes it is, but there is a partial divider under the crankshaft which retains some oil when the rest of the oil is drained via the normal drain plug.
Frank
By JohnStones
#89100
Hi & thanks for your comments
I used 14mm plug tap & threads are now visible
Applied Loctite "Lock&Seal to new sump plug & it tightens well
Hopefully will not leak when I add oil tomorrow
I'll see what happens at next oil change in 1800 miles
Has anyone used oil extractor via filler hole ??
