- Sun Oct 14, 2018 8:24 pm
#79601
I got a set of electra sliders pretty cheap... That said, althiugh they seem chunky enough, I'm not entirely convinced how well made they are in terms of dimensions. The slider rod sticks a long way out of the bottom, to the extent that I'm going to need a spacer washer under there so the nut doesn't bottom out on the threads.
In any case, I went for the tighter fitting gaiters which go under the cut-down shrouds. So here's how that looks OP.
I also took the oppertunity to fabricate a fork brace/mudguard bracket. It's not quite finished yet, should look ok once it's painted and fitted with some neat button-head fasteners and a silicone strip between the bracket and the mudguard.
