By Jamesy
#77647
Here is the photo
A.com?ref=t05cf5" target="_blank">Image
The rod is 5 inches long and the adjuster is 5/8 inches long. I
By Mark B
#77650
As Pete F says, the gearbox case stiffener is a massive help. Before I fitted one (fitting instructions come with it from Hitchcocks, and it's simple) you could see the cover flexing when you pulled the clutch in.
By another Allan
#77660
If the pushrod is expanding lengthwise due to heat, this will tend to make the plates stay apart and therefore cause slip. Jamesy is complaining of a crunch when engaging gear, which is likely to be caused by drag.
fwiw, I adjust out free play in the clutch cable. This gives a smooth gear selection and does not provoke slip. (Apart from if I accelerate hard to 65 in 3rd, change-up and then w.o.t. The standard clutch can't cope with that, free-play or not! Rolling-on the throttle more gently does not cause slip.)
