- Mon Jun 04, 2018 9:31 pm
#77341
Interesting. I doubt that the anti-roll sensor has anything to do with the ABS system. The one on the RE is basic by modern standards and doesn’t work while cornering. The higher-end bikes that have cornering ABS use an IMU (inertia measurement unit) which basically tells the ABS control unit the angle at which the bike is sitting. I believe the sensor you are referring to is probably the one that cuts the ignition if the angle of the bike is more than a pre-determined limit. It is a safety feature to stop the engine revving itself into oblivion should the rider crash and the throttle stick open. This isn’t unique to the Euro IV bikes; my 2015 has one. And, yes, they have been known to cause issues so it could be that. I had thought (hoped) that the better QA of the Euro IV bikes had put to rest the gremlins caused by el cheapo relays and fuses and their connections. Oh well. I’m sure we’d all love to know what the problem turns out to be.
