- Sat May 12, 2018 2:47 pm
#76739
Hi Guys------ when the Ammeter "flicks" then the points have just opened at the ignition retarded position---which is NOT TDC....So for tappet setting ignore the Ammeter and use a more physical approach...Ideally the cam follower should be at the very lowest point of the cam's base circle ie}---directly opposite of the cam's lobe..........Scotty's method is the "proper" way as it is based on this approach.....However for our low-performance, "Cooking" engines then the piston at TDC Compression Stroke will suffice.....
When setting a multi-cylinder engine one method of ensuring the valves required are in the right position is to use the "Key Number = No. of Cylinders + 1" method..................So, for a 4-cyl. engine the key Number is}---4 + 1 = 5.....Looking along the length of the rocker shaft we follow the firing order and to set Cyl. No.1 we look at (5-1) = No.4 and watch to see the rockers "On the rock" ie--one going down and one coming up"....When they are parallel we then set No.1 gaps.............With a firing order of 1-3-4-2 then the next to set is No3. and the one to watch is (5-3) No.2.............etc...Particularly useful on long, V12, V16 engines for example...Puts lecture notes away---goes back to being Mr. Nerdy !!
