- Wed Mar 07, 2018 8:25 am
#74638
Well - I bit the Bullet (No pun intended.)
Bought a champion WCX600 180 cap. ( 10KOhm). Coz they look right !
so I will have 15 kOhm total with the iridium in there too.
Had a look on some close ups on line. it doesn't appear to have the screwdriver slots for stripping to remove the resistor, so......
You know the best weather forecast - is to look out of the window ?
Well - I'm going to try it anyway. suck it n' see.
I'll eyeball the existing spark, and visually compare it to the new setup, with the plugs out of their nest, before proceeding.
As long as I'm not going to ruin any of the ignition components, I'm not over worried.
(Can always revert if it's a duff setup anyway !)
cap not yet arrived. I have a rubber booit (As they say in sunny Yorkshire) to fit betwixed cap and lead, to keep the wet stuff out.
Also bought some dielectric gloop for inside the cap.
if she runs ok I'll try the bucket o water test.(At the weekend - when she's not in demand !
If all is well - I'll report back here.
