- Tue Mar 27, 2018 12:26 pm
#75086
Adam,
how long have you had the bike? Has it ever run properly for you?
I notice you haven't replied to stinkwheel's points about using the kick-start, or possible problems related to the sprag clutch. I assume the K/S lever is still fitted and that you have been trying it. Does the engine kick over freely in neutral, apart from compression? If not something in the starter gear train might be binding, the sprag clutches are notorious for failing with this model, often locking things up completely.
Meanwhile, what EXACTLY happened when using the MG battery, did the starter motor crank the engine over but without getting the engine to fire, or did it struggle to crank the engine over at all? Your mention of "something odd about cranking speed" makes me wonder.
I also have to say there are some duff NGK plugs out there (possibly copies), you might be better off fitting a Champion N3C and checking for a spark while kicking the engine over. Bad sparks can also be caused by the oem ignition coil and metal plug cap packing up, it might be worth checking these, too as the bike is 11 years old. Providing you are getting a decent spark at the right time then it **should** just be a case of putting the plug and plug cap back, tickling the Monobloc carb and booting the thing into life.
