- Fri Jan 26, 2018 9:27 am
#73731
EP 90 has similar consistency to mid range engine oil - viscosity is measured differently hence apparent numerical difference - so what you use in the engine should also suit gearbox. I use 15/40 diesel engine oil because I've got a drum of it, same for gearbox, engine and primary chain case.... been okay for 20K miles, so guess it's suitable. Even though it's a detergent oil I find it remains clear and golden long beyond usual change time - so I've extended that to "when I get round to it".Only the gearbox requires occasional topping up as it loses a little, and I've contrived a dip stick to make this easy, only mod is a breather hole in filler cap to prevent any pressure forcing oil out. 350 iron bullet yr 2000.
