- Wed Nov 01, 2017 12:21 pm
#71838
Art, if you're changing gear ok when under way your clutch problem is not part of the gearbox. My advice would be to use the lightest springs you can, don't go heavy that makes it worse. Two suggestions, use ATF rather than ordinary oil in the primary case. It will probably help (it does for me) although some don't notice a difference. Second, when adjusting the pushrod free play at the cable end do it right up until binding and then back off just a tiny gnat's wotsit. This helps on all the Enfields I've worked on. One other thing, if you have new clutch plates make sure they are not too thick, the ones H's sell are very good quality but just occasionally can be a little too fat leading to a full clutch basket and little lift. And by the way, clutches are the bug bear of all Enfield owners, now you are a member of the fraternity you must share our pain! Good news is they are fixable, patience will get you there. And if not, you can always buy a Bob Newby version although you might want to sit down when you read the price....
