- Mon Jul 31, 2017 10:36 am
#69514
Me too. I fitted a carb to my C5 because I had a few issues with the EFI on it and the only ways to tune it for different exhausts and inlet systems are either a buy a Power Commander V and a suitable map (which you would have to change again if you fancied a change of exhaust etc), a Dobeck (?), cheaper but similar to Power Commander V but not as sophisticated, or a carb conversion. I chose the latter because it was less expensive than the PCV to buy and to make subsequent changes. It works well and IMHO looks better. No real need for the MIL, which I may replace with a nice ammeter. I'm far from being an anti-EFI Luddite though. On my last-of-the-line air colled Thruxton (bought because unlike the new l/c ones you can play with the tuning) I've remapped it to suit the airbox baffle removal (an easy and free fix that liberates 2bhp), the replacement air intake and air filter, the removal of the awful secondary air injection system and O2 sensors and the replacement of the anaemic standard silencers with Triumph Offroad ones. The result is a 16%increase in torque, the elimination of the dreaded off-idle stutter and perfect fuelling from tickover to WOT, with the rev limit increased by 500rpm. Waht a difference! How anyone can be satisified with the strangled performance of the standard bike is beyong me. Or with the brakes and suspension, which I've upgraded too. By comparison the options for the UCE are limited, though I might try rearding the inlet cam by two teeth, which apparently improves the mid-range no end. I'll wait until I fit a one tooth larger sprocket. Having recently changed the oil that can wait for a bit.
