- Sun May 14, 2017 10:50 pm
#67566
Bearing fit wouldnt work Adrian its been tried.
However Loctite do a product called loctite660 that is designed for loose fit bearings/keyways/tapers and that looks promising. Notwithstanding I shall attempt to get a replacement wheel, I felt I had nothing to lose with the original wheel as an experimental testbed so will see if I can get some loctite660 to see if it does what it says on the tin.
Andy
Andy
