- Thu Mar 09, 2017 7:12 am
#66417
Meanwhile, as Mark and WDC have already mentioned, you'll probably need
a new spring cap as inside female edge is inevitably burred, and will slip
off the kick starter shaft when your're winding up the spring. These cups
ain't cheap at approx $42 each, but using the worn cup is a ticket t6 the
Valley of Tears and heavy drinking. Also a another pair of hands helps if
your can actually persuade someone to help without blocking out the ligh
you'll be needing plenty of down there. Good Luck
