- Sun Mar 05, 2017 9:00 am
#66034
Neddy, The grooves are about 1mm apart but that's not the problem. Thanks for the reply.Ric, not sure what you mean. I thought Mr. H only has a P0 and P2 suitable for my requirements. Tim, I found a 4L13 in the Mikuni catalogue but its taper is nothing like the one on my mates bike. But, long story short, I may have cracked it. I had another 54mm needle (see my first post)so I cut 2 more grooves below the five (call them 6 and 7) so I can get it richer and put the clip in 7 and she goes like a rocket but the plug showed a bit rich so I moved to my leaner slot 6. Now it goes great and the plug is the right colour. I just have to test it out now at full throttle but I think it will be ok. I will do a couple of plug chops at different speeds. The set-up now is, standard 3 slide, 120 main, P2 needle-jet and 30 pilot and slot 6. Thanks to you all for your interest.
