- Fri Oct 14, 2016 5:11 pm
#63311
Oil passing down the push rod tunnels then winds up in the tappet chamber from which a couple of SMALL holes drain into the timing chest. I somehow don't think your vacuum pump will gain access.
Really Papasmurf, it's not a major job to undo the timing cover screws and just tap the raised alloy tabs on the AVL timing cover through from the other side very gently just to release it, especially if your Electra's gearbox hasn't been converted to right foot shift. Careful positioning of an old roasting dish or other suitable receptacle under the timing side of the engine will catch the old oil. All being well you can re-use the gasket on the timing cover (though they're not that dear from our hosts if you want a new one handy), and you'd have to be very unlucky to disturb the valve timing. Before the cover comes off though, you might also want to undo the filter housing end cap and remove the old filter with the oil that builds up in there.
