- Mon Sep 12, 2016 5:10 pm
#62240
Indeed, I had lost the washer which goes on the main jet. I replaced it with a small fibre washer from my plumbing kit, trimmed to size(ish). Carb back on bike together with known good spark plug and after much kicking, huffing and puffing including one loud backfire, I got it started. Only problem was, the engine revved excessively and carried on doing so after I turned the ignition off, despite having checked the slide was operating correctly. In blind panic I turned the petrol off and waited for the engine to stop. In hindsight I should have used the decompressor, I know. Reluctant to re-start it until I can get more answers. I'm beginning to think the Mikcarb should be re-named the macabre. However , progress is being made, thanks entirely to you knowledgeable chaps. As I said earlier, the bike ran faultlessly until I decided to "fix" a niggly fault.
