- Sat Sep 10, 2016 1:14 pm
#62201
Plan A not a runner, mounting covers gear box drain plug and interferes with the rear brake lever. So it looks like plan B making a mounting plate, using the thread that would be the rear thread of the current mounting plate and using the pillion foot rest mount, which is redundant on my bike other than for the silencer bracket. (Would just need a longer bolt.)
So Monday it is off to the local engineering emporium for some 1/4 inch plate, and 10mm drill.
I will then have to search for someone with a forge to heat and bend the mounting plate when I have finished cutting it to shape. (I don't like cold bending.)
Also the actual side stand I got was mounted on an 8mm pin that had just been riveted in place. I am replacing that with a 10mm stainless swivel pin bolt. (Needs something that strong to take my weight.)
