- Sat Jul 30, 2016 7:57 pm
#60748
The technology is different between mobile phone/camera AA type cels/batteries and those made for bike applications.
The end game fact of the matter is this: Baby it with a constant current, constant voltage charger if you prefer, But as soon as you install it, your bike is going to ram a ton of current into the battery, especially if half flat. I have had nearly 3 years out of Tornado's with no problems, and if andy is about, maybe he could comment on Thunderbolt's? Kevin has only had one for a year, so I will discount that.
As for fire, my charging system can sometimes indicate an amp or two going in, but I have never had a noticeably hot battery.
It says they can safely be overcharged at 4.2V. 4 cells times 4.2 = 16.8 Volts. Should not be a problem unless the voltage regulator is buggered, in which case, any type of battery would be in danger of damage.
Fit and forget guys.... (But do install an inline fuse if your bike does not have one).
REOC 15084
Tabellarius de verbis. Ostensor gaudium
