Update, checked the black and white wire a volt meter. There is no electrical current in the black and white wire, when the ignition is switched off and the kill switch is in the not kill position.
When I switch the ignition on, there is no current in the black and white wire. This is with the kill switch in the not kill position.
With the kill switch in the kill position there is a current being sent through the black and white wire. With the ignition switched off.
With the kill switch in the kill position and the ignition turned on there is no current in the black and white wire.
With all these tests out of the way, would this indicate that the black and white wire is in the right place? Being connected to the positive side of the coil?
