- Sat Mar 05, 2016 9:26 pm
#55970
Perorec,
are there several different pipe stubs in your breather can? I think that is the case with the can I took off my 2005 Electra-X years ago. It is possible that the rubber of the duckbill has degraded with age, which is why it will no longer fit properly.
Norm,
that's a fully working BT-H FM1R modified for the Bullet crankcase, and yes, there is a full set of timing gears driving it. There is a TCI sensor coil still fitted to the outer case should I ever wish to convert it to TCI, but it's not wired into anything. I think the larger brass NRV in the crank breather line opens at a slightly lower pressure than the NRV in the rocker breather line.
Les,
let's just say that Bullet Whisperer is no stranger to this engine. That's a Dell'orto PHF36, btw.
Scalyback,
think of our host's item 92674A painted (almost!) to match the bike with chrome side panels. If you ever do get some maroon tank badges sorted, let me know.
