- Sun Sep 13, 2015 6:03 pm
#50952
I don't think it is the case that nobody can make an electronic tachometer for the Bullet. For one thing RE themselves fit one to the CGT, as well as an electronic speedo. The issue here seems to be a lack of clarity on behalf of the supplier as to whether it is actually suitable for a single cylinder bike and, if so, what connections need to be made. As far as I can see it should be wired the same as a non wasted spark twin ie like a Brit twin with two sets of contact breakers. The tachometer only needs to know when a cylinder fires and what this represents in terms of crank revolutions. It gets the former from the low tension side of a coil; the latter it will determine from the type of engine, via the connections made,unless it is switchable according to the number of cylinders, engine configuration and type (2 or 4 stroke). It's not rocket science, just poor instructions and/or product knowledge by the supplier.
