- Mon Sep 07, 2015 7:04 pm
#50849
If the kickstart fouls the exhaust heat shield, it might be due to incorrect fitting (as I have just found out). I don't know if your exhaust is the same as mine, but mine has a chromed metal screen offset from the exhaust and anchored by four screws. The little wire guard that fouls my kickstart is attached to this. I took off the shield to change the pop rivets on the wire guard for machine screws and found that the shield wasn't seated properly, pushing it out by about 5 mm. There is a bracket welded (badly) to the exhaust under the shield that is supposed to seat inside another on the shield itself. As these didn't line up properly, the shield was sitting on top of the bracket not in it and leaving the shield too far out, so it fouled the kickstart. A bit of fiddling with a pair of pliers managed to align the brackets and sort out the problem. It also gave me an opportunity to ACF-50 under the shield as well.
On a different note, you may find assessing the oil level a bit interesting. When I picked up the bike from the dealers, I checked the oil, right to the maximum mark. By the time I got it home (40 miles) and put it in the garage, no oil was showing in the sight glass. Mild panic set it and I checked for leaks (none at all), though I did find that one of the bolts from the oil filter cover under the engine had fallen out. Luckily I had something which would fit. So I took the bike out onto the drive to see the oil level better, and it came back, not full, but just up to the min mark. Back into the garage, and it went again. Both surfaces are effectively level, so just a few degrees off will dramatically affect who much oil you see.
The rest of the saga of 'the search for my bullet's oil' will have to wait as I've just been told off by the wife for spending too much time on motorbike forums...
