- Thu Jul 30, 2015 7:38 pm
#49963
Nice workmanship, but very poor design! Not least that the former water drain out of the bottom of the brake plate is now acting as a Oil and Water scoop directing it into the hub!
You have changed the trailing/leading shoe positions reversed the applied leverage point, AND kept the old lever?
Whilst I can understand your wish for a better rear brake, your efforts would have been better spent simply fettling both brake shoes (Pivots and faces) so that they both sat True and Square to the cam and drum.
The stock std rear brake is perfectly capable of locking the wheel when it is correctly set-up...
