No progress today as I was out riding my 350 Bullet (starts first kick). It has occured to me that I probably disturbed the ignition timing while removing the exhaust cam to get behind the timing pinion to remove it. Tomorrow the plan is to first check the ignition timing. If that is out, then to re-set it and see if that restores the ability to start the engine. Then to try a new plug and see if that makes any difference. Finally to take the SR1 to a friend who restores magnetos and dynamos to see if he can check out its functioning.
Thanks again for all the contributions - I might have given up otherwise.
