- Thu May 24, 2012 9:22 am
#12861
Les one of the reasons for skimming the linings and hub is to ensure that they both perfectly match each other. This will maximise the lining contact area from the very beginning. In addition it also ensures that any malformation (good word if you play scrabble) of the hub due to wear, the wheel builders art or both is eliminated. Has anybody ever checked the roundness of their brake drum? I did once and was stunned at how far out it was.
However in order for the now round hub and linings to work correctly it is essential that they are centralised when the wheel is fitted. The wheel bearings will be a precise fit on the spindle but the brake plate will almost certainly have a clearance hole around the spindle. Centralisation is normally done by lifting the front wheel clear of the ground, spinning the wheel as as fast as possible and applying the front brake hard and fast. Continue to hold the lever very tightly when tightening the wheel spindle and any pinch bolts and/or torque arm fixings. Some people even have an additional .020 to .030 skimmed out of the central hole in the brake plate to ensure the centralisation can be achieved.
The efficiency of twin leaders is also dependent upon getting the adjustment of the operating arms absolutely spot on. HTH.
