- Wed May 27, 2015 9:53 pm
#47958
The girder fork in the earlier link looks like one of those brittle cast ones from India that are known to fail in use.
It's certainly worth using the TLS brake, if they are set up properly you can do stoppies with them, also when laced into a 17" rim they are even better, with the improved mechanical advantage.
Not sure if it is relevent, but the headstock bearings on a 1954 Redditch Bullet frame mate perfectly with Indian fork components.
