- Fri May 01, 2015 5:12 pm
#47259
Girlish, your opening statement about performance and longevity is bang on. Any external work you can do will only provide marginal gains, but will reduce the life of internal components. If you are embarking on performance modifications start on the inside first. Roller big end and steel con rod should be the very first things on a very long list of expensive internal modifications.... Otherwise your quest will end in tears.
