- Fri Apr 24, 2015 5:00 pm
#47035
You are right Pete about air leaks, and of course if they were serious enough then oil wouldn't be drawn up the tube at all and the method would fail completely and accurate timing would probably be the least of your worries!. However if the leaks are minimal (as in my case) and the tube is marked beforehand it shouldn't matter. The air leaks would be consistent and apply equally to both your BTDC and ATDC markings. Additionally it is a very easy thing to repeat the checks several times to ensure your markings are correct.
